VH45 s14 S/C
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
justinedible4
Car: 1990 Honda Accord, 1991 S13 HB
Man I just read through your entire thread on zilvia and on here. I have to say that this is the greatest build thread ever! VH45 is certainly going to be the new bandwagon with builds like this.I need to scrape up the engines fast!
T45
Car: King Kong powered Z32
SuperHatch wrote:
I've got some spare phase 2 injectors if you need them...
Thanks. I have to find out which one(s), if any, need replacing. I did a quick consult troubleshoot turning off injectors and couldn't find any one that changed more than the others. I wish whatever it is would just break so I could find it....just not in the middle of nowhere please. lol
newbissan-tech
Car: 96 vh45 swapped 240sx SOLD, 2011 frontier pro4x SOLD, 08' Altima SOLD, 2006 TITAN, 2012 SUBURBAN FOR THE FAM.
let your car idle for a bit then just pull your plugs and see which one has fuel on it or smell the tips then you will be able to find it! alot easier than pulling everything down untill you absolutely have to!
tmorgan4
Car: 2000 Nissan Pathfinder
I'm not sure if your cars are set up like mine but it's a huge pain to pull the plugs!!!
Carl H
passenger bank in my vh s13 wasnt too bad to get to...drivers bank however brake master and booster had to come out for sure.
gs14racer
thats wierd, i can remove all my coils and spark plugs with out removing anything..
Carl H
probably has to do with mounting, my engine was mounted level with the xmember while i think the mazworx kit places it lower than the xmember...correct?
SuperHatch
Car: 96 TLC
Carl H wrote:probably has to do with mounting, my engine was mounted level with the xmember while i think the mazworx kit places it lower than the xmember...correct?
Don't really know how the engine can be lower than the crossmember?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I think he means oil pan lol.
SuperHatch
Car: 96 TLC
Yellow4g63 wrote:I think he means oil pan lol.
Good point, bit of a brain fart there...
Yeah that could do it. FWIW, I can chance my plugs with the booster in as well, on both the S14 and the Z32.
CrazyTrance
Car: 1991 Nissan 240sx - vh45de
gs14racer wrote:thats wierd, i can remove all my coils and spark plugs with out removing anything..
Me too.. just takes some creativity with the order you put the socket on, extension, and eventually the ratchet. But it's not that bad. Takes some finagling.
T45
Thanks for the help guys. Haven't been home in about 3 weeks, been working. Also getting ready to move to Houston in a week or two. One of these days I'll get some time, parts, tools and a place to dig into it. I just know something isn't right.
The first VH I had in there was like butter smooth. Typical with the VH, you couldn't feel a thing inside the car. But this one has a vibration that is consistent with rpms, unfelt at idle and WOT and seems to richen up the fuel from time to time. I ran BG44K through it first miles and the idle would creep up every so often, telling me they were dirty. It finally leveled off and was good from there out. Ran the piss out of it racing a SRT-8 and the idle jumped up 500 or so and hasn't come back down, exh smells much richer than before, especially in the morning.
I may just get an entire set from Deatch and be done with it. I'm the kind of guy that will replace any part that is believed to be less than normal. If I have one injector clogged/bad, the rest are sure to follow eventually. Just sucks they are so damn expensive new...
zmech
You are my hero...I have been eyeballing the superchargers for the mustangs for sometime and now here it is. Attached! Thank you thank you thank you...Now I know what I have to do for the Z45.
http://forums.hybridz.org/showthread.php?t=152957
kbflip02
Car: 1994 Infiniti J30
2006 Infiniti G35x
just out of curiousity what rear end are you running....been following this pretty closely as im hoping to put together a similar setup in a new project...
SuperHatch
Car: 96 TLC
kbflip02 wrote:just out of curiousity what rear end are you running....been following this pretty closely as im hoping to put together a similar setup in a new project...
Jerry has the J30 read (3.96:1) right now, but last I spoke to him he was considering the G50 Q rear (3.54:1)
kbflip02
2006 Infiniti G35x
thats freaking awesome!!!
T45
His 450 could use a TTZ or Q rear end, the blower just melts those 315 rears, I would say through 50-60 mph easily. lol
kbflip02
2006 Infiniti G35x
T45 wrote:His 450 could use a TTZ or Q rear end, the blower just melts those 315 rears, I would say through 50-60 mph easily. lol
that should help the top end...
Loch Ness
Car: ThE BeSt oF NiSsAn
q45 is the way to go TT rear is more involved than the q45[diff,z and q45 axles,,new driveshaft or flange]
Steve Lloyd
Q45 and TT rear ends are the same, unless you are talking a 97-01 Q45, then you still need J30 axles.
Loch Ness
the rear cover bolts are different
Loch Ness
Loch Ness
u do realize that the diff is kinda offset
SuperHatch
Car: 96 TLC
Steve Lloyd wrote:Q45 and TT rear ends are the same, unless you are talking a 97-01 Q45, then you still need J30 axles.
No, they are NOT the same. Please stop spreading misinformation.
Q45 90-96 is an R200V 3.54:1 with 6-Bolt high spline count output flanges and a large 4 bolt input flange. It is a BOLT IN upgrade for S chassis cars when using one Q axle, one Z axle, and TT hubs. It is stronger than any stock s chassis/J30/Z32NA rear.
Q45 97-01 is an R200V 3.69:1 with 5-bolt low spline count output flanges (came as stock S chassis) and large 4 bolt input flange. It is also a BOLT IN upgrade for S chassis cars. It is no stronger than any s chassis/J30/Z32NA rear but it has a taller ratio that is the same as Z32TT.
Z32TT is an R230 3.69:1 that is much larger than the R200. It physically does NOT bolt into an S-chassis car. The output flanges are the same bolt pattern as the 90-96 Q, but the input flange is a 6-bolt CV style joint.
Loch Ness
rookie
Jeff Taylor
Car: '96 240sx, VH45DET, 819wHP
gs14 - Any upcomming plans to upgrade the fuel system? I'd imagine your OEM injectors are near 100% duty cycle at that HP & lambda.
I had trouble finding aftermarket side-feed injectors that would flow the amount of fuel I desired, so I ended up fabricating a new intake manifold that would support top-feed injectors.... It was a PITA because the manifold project was the first time I ever welded aluminum and had to learn along the way. Fortunately, I could probably make another (better) one in 1/4 of the time now.
Are you running an aftermarket fuel pressure regulator? It would require some ingenuity to adapt, however it would probably be an inexpensive and much simpler method of increasing the engine fueling. Raising the base pressure from 43 psi to 65 psi would give you a 23% flow increase, which may be good for another 1-2 psi of boost.
Great looking setup!
Jeff
tmorgan4
Wouldn't one of the Nissan aftermarket adjustable regulators work just fine? I'm using a factory fuel pressure regulator off of a VQ30. The one that came with my engine was completely plugged and the performance shop across the street dug up an old one off a VQ that was identical (on the outside, anyway!!!).
Jeff Taylor
Yeah, true.
gs14racer
Jeff Taylor wrote:gs14 - Any upcomming plans to upgrade the fuel system? I'd imagine your OEM injectors are near 100% duty cycle at that HP & lambda.
Jeff
Well i am already running 65 psi rail pressure and i see 100% duty cycle in the upper rpm ranges, i am running the timing a slight bit conservative on the top end will pretty much after 5500 rpm.
As for the aftermarket regulator, any nismo adjustable regualtor such as those for s13 sr20dets, the most common one available, bolts right on to the vh fuel rail with just a little rerouting of the stock return line.
As for upgrades, ive already confirmed that nismo/tomei as well as subaru injectors fit into the vh45 series 2 rail with no modifacations. Now that christmas has past i will have a little more money to spend on the car and will be upgrading to 750cc injectors and an external fuel pump with -8 feed lines and will be dual feeding the rail as well.
The maf is also slated to be upgraded to a ford lightning unit as at 6500 rpm it pegs 5.114 volts. So after all this is said and done ill be uping the boost a bit.
Jeff Taylor
Great to hear. Will the series 2 fuel rail bolt to any VH45 ?
Return to “VH45DE / VK45DE / VK56DE Forum”
