Secondly, when I am deleting all unnecessary vacuum, I'm not quite sure what these two solenoids (third picture) are on the front of the motor above the CAS do and if I can delete them.
Fkhuk wrote:I pulled my manifold off today to start deleting some things and inspect the motor and what not. I'm sure some of you have deleted EGR and accompanying emissions components and I was hoping you guys would be able to help me out. First off, if I keep my Idle Air Control Valve, do I need to keep the Y (In the first picture) that leads to that pipe (second Picture) that runs up the block to some sort of something, or can that be removed and a line run to just the intake manifold, and intake piping?
