VH45 S13 cylinders 2,4,6,8 not firing
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
scs13
Car: 93 s13 coupe
im having a problem with my vh swap in my s13. as the title says im not getting any spark from cylinders 2,4,6,8. i have checked all the coils, ignitor and the harness and they are all fine. i also dont have an fsm for a 1990 q45 to check the wiring so any help would be greatly appreciated, thanks!
goody90q45
Car: 1992 Infiniti Q45 (sold)
Gotta ask, but is the ground connection at the end of the harness, past #8 cylinder, bolted to the engine and corrosion free?
The coil harnesses get hot and brittle since they're covered by the spark plug/coil ornamental cover. Did you check the continuity of each of the wires back to the connector with a voltmeter, especially the ground wire?
scs13
Car: 93 s13 coupe
I have swapped coil pack harnesses from one side to another and no change. so I know the harness is good. I assume it is a problem within the engine harness or something just dont know what pins to check.
b20vtechb
Car: 90 S13 hatch
VH45det in progress
its most likley the ignitor or the ground as mentioned above. try swaping the left and right bank ignitors.
scs13
Car: 93 s13 coupe
As I said above, I've already done all that. Seems it has to be a wiring issue in the engine harness. I will probably just swap the entire harness since I can't find an fsm for a 1990-1993 Q45.
goody90q45
You can use the 1994 FSM:
http://www.nicoclub.com/FSM/Q45/1994_Q45/
or buy mine (forgot that I still had this):
post5710170.html#p5710170
scs13
Car: 93 s13 coupe
The one I have for a 94 shows a different plug for the ignitor.
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
Did you get this figured out?
Return to “VH45DE / VK45DE / VK56DE Forum”
