elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Mon Jul 04, 2011 2:40 pm
Looks like you got a TCS engine... you'll want to swap out the TCS TB (with the stepper motor) with the non-TCS version that you got, no big deal as the TPS and all the other bits are the same. I assume you already have some sort of intake pipe fabricated for the other TB so you can reuse that.
The injector plugs are different, the older ones have the square style with the locking pins on the side, and the newer ones have the round ones with the tab.
The cam sensor actually works the same, you just will have to splice in the different connector into yours. The cam sensors are not interchangeable old vs new as they changed the way they mount into the head.
