what about a gasket kit and such?maxnix wrote:Too much money.
Inspect and purchase and rehabilitate a JDM take out per Q45tech's method.
there are none localy, ive been looking alot. and i want to have this swap done by april or may. and i wanna keep it under 1000 bucks.qship96 wrote:Leave the 93 in the junkyard where it belongs and look for a well running 94 car for sale locally- they can be found all day for roughly 2,000 with a good running engine that wont need rebuilding, or chain guide replacement like the 90-93 motor does.You can then part out the rest of the car and recoup much of your 2,000- almost like getting the engine for FREE!!!!
if im lucky enough to even find one around here. lolppastos wrote:The above or you if your lucky and you fell like taking a chance find a nice late 1993 and see if it has the metal guides, Might be a 50/50 chance or better.
there is a lack of q45s here. ive been looking for about 2 months now and im lucky to run across this one. the guy said he will pull it for me and everything for 200. cant go wrong there. if its toast, im out 200 and i have extra parts.qship96 wrote:Why take unnecessary risks???? people get fired for that in the real world
Holy sh!!t batman. maybe i shouldent get into this engine then. thats nuts. thought these engines were a dime a dozen. how do i check to see if it has the metal valve guides? and does not the 94 have the same problems with the injectors and exposure to ethanol also? what is the chance of actually finding a 94 in good running condition anyway?qship96 wrote:Even if you get a "good one" for 200....you will need to spend $2,000 minimum to update the chain guides{ only on 90-93 engine} and replace all 35 or so hoses under the plenum along with knock sensors...then you have the issue with the early fuel injectors failing from age and exposure to ethanol in current fuels...possibly another $1000-1500
Your $200 engine {IF it doesnt need rebuilding} will cost you a real $ 2200 to $ 3700{NOT INCLUDING LABOR} by the time it is ready to install and use....NO WAY AROUND IT never confuse price with cost.
The new long block from the dealer is close to $10K. You have to inspect the timing chain guides, the camshaft chain tensioners, the oil pump drive chain, the thermostat and water pump, the VC gaskets, KS and harness, under plenum hoses, EGR and IAC valves, the TB and the plenum itself. Alsoflow test the injectors. Replace all hoses. About $2K for parts.Piper wrote:
That's all true too. I think the new engine is just over $10k!maxnix wrote:
The new long block from the dealer is close to $10K. You have to inspect the timing chain guides, the camshaft cahin tensioners, teh oil pump drive chain, the thermostat and water pump, the VC gaskets, KS and harness, under plenum hoses, EGR and IAC valves, the TB and the plenum itself. Alsoflow test the injectors. Replace all hoses. About $2K for parts.
A twin cam, all aloy 4 valve heads, coil on plug design with each cylinder is not a cheap design, nor is its assembly haphazardly executed.
i dont know where to even look for a jdm engine. and i would do all the work myself, ive done full rebuilds before, but like i said it was all on 420a, 4g63, and ka motors. and why would it not feel the same?Kiven422 wrote:You should search for a low priced JDM take out. The deals are out there!
Sounds like your about to do the work yourself anyway. I'd do it myself too... This is one of the easiest engines I've ever worked on.
P.S. I favor the 90-93 engines for their strength.
Besides when you open the engine up.... it just won't ever feel the same after.
I will do just that, thanks!AlabamaDan wrote:Not that this isn't an interesting thread, but the forum on VH/VK engines might be more educational for you over there. Not everyone in this forum tears into their VH much past valve cover gaskets, plugs, injectors, etc.
Dearborn is about 10 mins away from me give or take with traffic conditions. Thanks for looking that up for me, I will give him a call today or tomorrow.Rex wrote:Long story short ...
If you're looking for a donor engine, look for 94-95's. Most likely any 90-93 in a junk yard didn't have the guides updated. It's not an absolute, but a safe bet.
How far are you from Dearborn?http://detroit.craigslist.org/ctd/903683632.html
You can part out a lot of the car and get some of your $$ back.
So if i run a leakdown test and compression test, other than that, this engine has no known major problems? No crankwalk to look for or anything of the sort? I just want to do this right, and as cheap as possible.If it takes more than what im looking to spend, im ok with that, so long as it is right and i dont have to dig into it every weekend to get it running again.Unnatural1 wrote:
Before you do anything with this you need to go through it thoroughly. If you don't replace anything else under the plenum, replace both knock sensors and the harness. You've already mentioned that you will be getting new gaskets and I would add all coolant hoses to that list. Take this opportunity to replace any cracked/damaged vacuum lines. Some of them can be bulk vacuum hose and others may have to be dealer items. I would pull the injectors with the rails and send the whole thing to DeatschWerks and let them test them for you. They will check coils and flow test them for a reasonable price (mention you are from NICO).
To check this engine out of the car, you have to use a leak down test. You need a leak down tester an air compressor for this for this. But, short of tearing the engine down this is about the only option with the engine out of the car. A leak down test can find worn rings, damaged valves, combustion chamber leaks, etc... It can't find a bent rod however like a compression test may. But, removal of the oil pan can allow you to check for that. If the engine rotates freely and passes a leak test, and you've checked for bent rods and bottom end damage, you don't have to go any further. The engine should be mechanically sound and not require new internal components or disassembly.
If you end up buying a boat anchor instead of an engine, tear it apart and save what you can and sell the scrap to a metal salvage yard. When doing an engine build up it never hurts to have extra parts.
A leak down test will be the only test you can do on an engine that you can't crank over with the starter. Of course, you can always tear everything apart and inspect if but that's not easy. With a leak down test, you want each piston at top dead center on the compression stroke (with all valves closed). Then you pressurize each cylinder one by one with compressed air and measure the rate the compressed air leaks out. Most engines will leak some (even new engines) but you are looking for excessive leak down. The leak down test has a gauge that is marked in percentages to measure the size of the leak. If you do find excessive leak down you need to listen to where the air is escaping. Can you hear air escaping into the intake manifold, exhaust, or into the crankcase (remove the oil cap)?Piper wrote:So if i run a leakdown test and compression test, other than that, this engine has no known major problems? No crankwalk to look for or anything of the sort? I just want to do this right, and as cheap as possible.If it takes more than what im looking to spend, im ok with that, so long as it is right and i dont have to dig into it every weekend to get it running again.
Thank you guys very very much for your information and ideas.They are very very helpful!!
Well this Friday I will head to the yard and do a quick once over and remove the timing chain cover to see if anything looks broken or if im lucky and get one with metal!! Anyone have a pic of what the visual difference of the two are? And also what a broken one looks like? Thanks!!Unnatural1 wrote:
I know of no MAJOR problems other than the timing chain guide issue. Crank walk is a later model 4G63 occurrence. That sort of thing is not typically seen on other engine that I've seen or read about. From what I've read it's typically caused by oil starvation to the main bearings in the later 4G63 blocks.
If you decide to add forced induction or nitrous in the future you should know the VH has cast pistons that will probably become the weak link in the engine. All evidence is that the rest of the bottom end is very strong. One the other hand, KA's have cast pistons too and I've seen some insane power numbers from those engines under boost on the stock engine components. For reliability, new pistons are going to be required, in my opinion. There are a few people running VH under boost on the forums and so far I have not heard of a failure...but someone else may have.
This engine comes from the factory with 6 bolt main caps and a deep skirted block with thick reinforcement webbing cast in. Very ahead of it's time I think. Everything about it screams durability. That shouldn't be an issue once everything else is sort out.
Again, if you can find a good engine from a 94-95 Q45 then I would consider buying that and saving yourself some work. But for the price, this engine may be a good deal. Even if it turns out to be bad you either have extra parts or part the good pieces out and recoup some of the money you spend. It could also be completely thrashed. The moral of the story is check it first with a leak down test and remove the oil pan and visually inspect the bottom engine. You may remove a main and/or rod cap and inspect them too.
Thanks for reading my novel!
~Brendan
Isn't the average cost of a JDM takeout roughly $5k? $3700 sounds like a bargain.qship96 wrote:Even if you get a "good one" for 200....you will need to spend $2,000 minimum to update the chain guides{ only on 90-93 engine} and replace all 35 or so hoses under the plenum along with knock sensors...then you have the issue with the early fuel injectors failing from age and exposure to ethanol in current fuels...possibly another $1000-1500
