VH45 mounts for Z32
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
ZedZillaZ32
Car: 300zx TT, 280zx NA
Is there anyone with a VH45 Z32 prepared to sell a copy of their engine mounts?
Any help would be greatly appreciatedCheers Tobias
ZedZillaZ32
anyone working on this atm I can discuss the project with?
John Dixon
Car: 300ZX-TT Z32
Yes, I can do them no problem.The ones on my car are solid though as its a bit of a racer, not sure if that's what you're after or not?
ZedZillaZ32
I dont think that will be too much of a problem , mines not a daily driver anyway.
Im having problems getting into my email at the moment but Ill love to get in touch about this. Im even prepared to call you up if you dont mind.
Let me know which you would prefer
John Dixon
Car: 300ZX-TT Z32
Email is probably easiest.I should be going over to do some work on the car this weekend, so can hopefully get the jigs for the mounts made up then.
ZedZillaZ32
That would be great. JOhn do you still use the [email protected] email? I sent you a message but didnt get a response.
John Dixon
Car: 300ZX-TT Z32
Sorry mate, have responded now.Not on line for more than a few minutes at a time at the moment and normally have 100+ emails to sort through.
Zak427
Car: 93 2+2 Twin Turbo
it's putting to gether the parts i need to do a swap into my 2+2. beside mounts radiator, adaptor plate for transmission, and ecu what else do i need, what do i keep and what gets thrown out, and could you write me up a walk though?
SSDwellah
Car: '90 Z32 Coupe w/ VH45DE + 5-speed (FOR SALE)
'06 Infiniti G35 Coupe 6MT
'08 Frontier 4x4 SE KC
I am interested in mounts too. I have a 1990 Z32 coupe with the VG30DE and, even more unfortunately, an A/T. This is my first car with and automatic transmission and I will never buy one again.
Anyway I have been thinking for a while now to go to another engine swap like perhaps a VQ35DE due to the light-weight aluminum block but the cost is still very high. The VH45DE makes a lot of sense but there haven't been too many people doing things with it yet.
I would be interested in mounts for a Z32 also.
SSDwellah
I'm gonna have to ressurect this. Does anyone make Z32 mounts for the VH45DE? I know it has a lot to do with which trans you use, etc.. but it would be money if someone like McKinney Motorsports (famous for RB into s-chassis mount kits) would make a set of mounts and trans adapter. Because then you would see a whole lot more aftermarket parts since the fitment would be finalized.
ultrapulse
Car: z32 300zx, Hilux & Datsun utes
Mine should be done this time next week if u wanna copy them.
SSDwellah
That would save me tons of time and money. I don't have a lot of fabrication tools and time to have this car sit off the road during the swap. Maybe those are arguments why I should NOT be doing this swap
ultrapulse
Here they are. Factory on the left, new and improved on the right:). It turned out both of mine are the same within about 3-5mm at the mount stud so would almost fit either side at5a nudge, pretty hardcase. I ended up using nolathane mounts designed for Cortina 71-77 MK3 2.0L, 3.3L, 4.1L, Repco # MT8156N (black nolathane). They are 70mm diameter and 35mm thick using 10mm stud. A similar one is also used for MK4 6cyl but are 2mm thicker which if u sorted the angles will also be cool. They are cheap, infact i bought 4 so I can convert my z32 factory mounts since they always break when given arseholes.
sinfiniti
Car: Z32 (soon VH45DE), 1971 Datsun 1600 P510 (SR20)
They look well built, although they do look like alloy.... :/ are they?Also have you tried fitting them yet, as without a locating pin (as per factory) and an elongated mount hole, you may find them "non conforming" to your wishes.anyways best of luck and let me know how they go for fitting..P.S. did you draw up some templates so we can do the slack approach and copy yours :P
sinfiniti
ok ive just figured they're alloy, as per my previous assumption you must be a Welder or similar by trade?
ultrapulse
The elongated hole is in the zed crossmember, and have pulled them in and out a few times doing the trial. They work mint, but I had to slightly oversize the hole in the mount so that I can more easily remove/ replace in situ. Dont need the mounting dowel as the ford mounts are symmetrical, and managed to do up the locknuts without them spinning, maybe its just the weight of the engine on them, or I held them, cant remember but piece of piss. i havent shown the heat guards, as i used the factory ones and modded them so the mounts wont get cooked if the zorst gets too close to them. I havent got templates but can forward on any measurements, all depending on where your engine sits in yours longitudinally. Havent really got time to make them again, though could probably get someone to copy them out of steel quite cheap (in NZ $ and all).
sinfiniti
nah thats kool, email me your measurements if you can. would provide a good baseline to work towards.Im making mine in steel.Again, what did you weld them up with TIG or MIG?cheers
ultrapulse
Tig, as thats all we have at work. Mig would be HEAPS quicker, and appearance (v's tig) wouldnt be too critical being way down there. I am looking at buying a mig but just waiting foir a deal to come up:)I will posta better closer up pic with measurements to go off. Quite straight forward and will only mean moving the main centre bit back or forward on main plate depending on exact engine location. Here are a couple more pics which I emailed to a mate who makes good headers, and I'm too lazy...Big new years so hitting the sack now. Will give measurements nexttime im on here
Modified by ultrapulse at 12:45 AM 1/1/2007
Modified by ultrapulse at 12:47 AM 1/1/2007
SSDwellah
You are the man! Looks pretty good considering the tight Z32 engine compartment.
ultrapulse
The 60mm wide piece started off as a 180mm x 60mm length where I ground a slot to bend on that angle. However it turned to **** on the crease even though I had slotted it, just this tough ali isnt forgiving with tight bends hence the welds both top and bottom. So if u use steel u should be able to use a 180mm length just bent to suit the angles. To get the angles exact u will probably need to tack in situ. I didnt measure those, just made suit whilke bolted up. I marked and put good tacks on the main rectangle bit and the main outy bit....slightly bent to the right place then made and welded on the side plates. I did the same design on both as one mount is easy to get from the front and one from the rear making the studs very accessible.Thats enough typing and time at the mo. Good luck.Hope this helps.
SSDwellah
How is the project coming along? Were you able to find a good deal on a mig?
ultrapulse
Yep got a mig but busy looking at moving house so on hold for a wee while, hope not too long
SSDwellah
I'm curious if you were able to clear the hood up top with these mounts and the sump down below?
ultrapulse
The mani I made just clears..only just. A factory one would still hit I reckon. As for the sump I had to make a rear buldge, as there was no way the factory front sump was gonna work in the zed. (currently getting headers done)
aeary
Car: 1993 300ZX VG30DE (450Z project)
2005 Dodge Magnum RT
@ultrapulse:
I know this is a long time past the last post, but was hoping to resurrect a bit to discuss. I just picked up a 93 N/A Z32 and am planning a VH45 swap. Wanted to see how yours went and how the headers fit with the motor mounts above?
Return to “VH45DE / VK45DE / VK56DE Forum”
