Honestly, if you're fronty is an auto I have read over and over that all nissan automatics use the same pattern on the bellhousings where they bolt to the transmission. Try and find a pic of a fronty bellhousing and I know there are plenty of pics here of the VH bellhousing.
The only things that are actually NEEDED for the ecu to operate properly are pretty simple actually. When you get the vh out you'll see the most beautiful thing in your life. An engine harness that is separate from the rest of the engine bay. That's what makes swapping nissans so easy. Almost all of their cars and trucks have separate harnesses for the engines and body.
The engine harness is already together. All the injectors, coils, MAF, TPS, O2, etc are already done. All that you need to do is hook up the rest to your truck. I don't have the wires off hand but it's only like 10 or so.
The ecu doesn't need anything from the trans at all, or even the vehicle for that matter.
http://www.youtube.com/watch?v=nIbK1AiQNhs
There is much much research to do but you will learn a ton about engines and nissan engines in particular. just start reading. lol
The Q trans can be used after you get the tcase bolted up to it. I have never done that but maybe someone here has, I have only read about it being done.
First I would find me some pics of fronty bellhousings and compare to the VH. It may be bolt and play if you have an auto.
