vh45 injector question
Zenki-des
Car: s14
do the vh45 injectors need modification to work in the kade rail?
rotorimp
Car: 02 Xterra, 60 IH Metro
No--but they have a different design on the business end which alters the spray pattern and they are only 370cc
WDRacing
But they do work fine. 370's are good for a low boost setup, 10 psi or so.
WD
Chezedik
Car: 1991 Nissan 240sx
Mine are a little taller than the stock rail, I haven't tried it, but it doesn't look as if it will seal. I think I can take the Q45 rail and cut it to relocate it so that the injectors sit in the right place and weld it. I will sell my set if anyone is interested in trying it out though. I will do 60 shipping in the rail with the regulator.
Chezedik
Pulling that tip makes them look as if they would spray like our injectors, FWIW.
