i was told the one is off of a 92,(bottom one in the picture) and the second one that i pulled, is off of a 93.(top one)
some of the plugs are the same, others are different. now,(such as the CAS) which one should i use? does it matter?
ok, next, can i use this cas on this motor? it appears that the ears on the one on the right are different than the original.... im kinda lost here, i was told that the replacement i got would work on any s1 motor, but its def different.
ok, lastly, here's both ecu's that came with the harnesses. they appear to be able to plug into either harness. now, are they interchangeable? can i send one out to get chipped and switch it out later?
any help and info would be appreciated.
