VH45 emission, IAC and AAC delete questions
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
VelocityStars
HI guys,
actually just picked up a vh45 with the tcm butterfly valve in the throttle body. i have a few questions regarding deleting alot of the non sense on this motor. I have been searching around in this section and you guys have stated good points but never really got an answer to a question i had.
ok for one regarding the coolant lines through the throttle body can they be deleted?
2. Looking over the motor i see that the aac valve is connected to a tube that runs under the the lower intake plenum and is vented to the atmosphere, i guess i can say the same about the IAC.....can these both be deleted off the motor? or will i need a standalone to run it? keep in mind this is a dedicated track car..
3. is it worth it to get a new throttle body or do i just delete the butterfly valve in the throttle body?
Return to “VH45DE / VK45DE / VK56DE Forum”
