VH45 Bolt pattern
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
redhat-z
These are the dimensions I came up with for the bolt pattern on the back of the block based on crank centerline. Can anyone with a working adapter plate verify the accuracy of these dimensions?
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
You should use mm, since the engine was designed using metric. You'll find the measurements end up a bit more logical.
Imperial is a relic of the past, used only by backwards countries.
redhat-z
Thanks for the jab to the ribs!
redhat-z
Does this work for everyone else NOT in backward countries?
tmorgan4
Car: 2000 Nissan Pathfinder
How did you come up with these measurements? I'd be very surprised if it's not a completely symmetrical pattern.
redhat-z
Very careful dimensioning of the back of the block over the winter and rechecked about 12 times. It appears that the pattern is symmetrical, just rotated slightly counterclockwise.
tmorgan4
Using what? A tape measure or a CMM? Calipers?
redhat-z
Calipers.
tmorgan4
Did you delete the measurements? I was going to try and double check some of the measurements tonight and see if I came up with similar numbers but the dimensions are gone.
redhat-z
Oops. Fixed.
nat0Z
Car: 240z
in pink is your holes, my shape is from the spacer plate, but also not confirmed.
cheers nathan
tmorgan4
Nathan...Do you have a price on the VH and VG patterns? Your other drawings have helped me tremendously and I'm thinking about building a midplate to help support the engine. If you'd like to trade a few $$$ for the drawing I'd be interested!
nat0Z
Car: 240z
lol,
how bout i just come and work for ya.......
i thought thats what you were gonna say when i saw you had posted under this topic.....
that dwg is based off the spacer plate like shown, a VG & a VH item appearantly one hole was out about 0.3mm off the vh one, my mate had an adaptor plate made, althougha lil bit rough as it was. still worked.
What do you want and how much you want to chuck my way.
I dont do these for cash but if people are willing to sponsor these efforts it does make me more willing to share, once they are complete. Im glad the sump flange helped you out, as once you had it sussed your sump was completed quite quick.....
I tried to match up the above posted items with a lil bit of rotation, but ill be honest and say i didnt spend long, just scaled the pic posted, drew in the holes then super-imposed ontop.
I am still yet to get back onto my VHswap unfortunately...... maybe soon.
trying to sell my r34 at present.....anyone interested???
sorry thread hyjaquing.....lol
nat0
RYANW501
Car: Stock 1995 Nissan 240SX. In process of vh45de swap. Can't wait!!!!
natOZ can you send me that cad file
88 P-body
I too am putting a VH45DE in something and need a cad drawing of the bolt pattern so I can make an adapter. Anyone here have one in file form that i could use?
Joe N.
Return to “VH45DE / VK45DE / VK56DE Forum”
