SeanDean wrote:If your adapter plate is only going to be 1/4inch thick (must be steel I would assume), then forget spacing the flywheel. Use a Z32 NA flywheel bolted directly to the crank and the VH starter will work fine. The Z32 input shaft and pilot journal will work just fine sitting 1/4 further out.
This will probably work but will definately require some bellhousing machining to allow for starter snout clearance.
I think that's why most people just use the Z32 starter as it mounts to the trans and needs little to no modification to make it work. Some machining is needed of the VH block in the starter mount area for snout clearance but that's no big deal.
The ideal setup is a TT trans, clutch and starter with 1/4" adapter and 1/8-1/4" spacer. That factory A/T spacer is dead nuts flat and accurate and I wouldn't hesitate using it behind my flywheel. I believe it's machined and not stamped. Then the only mods needed are clearancing the block, and you have a stronger clutch setup with a lot more options for power holding clutches.
