elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Mon Oct 01, 2007 12:56 pm
Just letting you know i have my eye on this. I will try and be more detailed later, but heres the crash course.
The tailshafts are different, the 03a has a larger yoke so your hopes, dreams and aspirations of the driveshaft bolting up to an 03a are out of the question.
Im not sure if the tailshaft HOUSING is different so you may be able to bolt that to an 03A for the cause of using a transfer case. I thought all the 4wd systems used the 03a, not the 01a. at least, thats how its done in NissanLand. Also, the trans was controlled by a seperate TCU transmission control unit.
The VH41 is not really that might tighter of a package, the only thing that renders itself easier to swap is that on the VH45 the alternator is on the side, vs the VH41 on the top. The alternator is almost always what gets in the way of tight swaps...
ALSO, IMPORTANT!!!!!! THE US VH41 IS SIGNIFICANTLY DIFFERENT FROM THE JDM VH41. I would NEVER EVER EVER ever swap a US VH41 into anything, its just not worth it, its a stupid motor and its almost different enough to not be a VH.
The JDM VH41 is nearly identical to a VH45 except the smaller stroke, the different accessory orientation, and a duplex timing chain setup vs the single timing chain setup. Arguably, the ultimate VH swap would be VH45 internals into a VH41 chassis if you will.
The physical dimensions are in the VH forum somewhere, going off memory its like 500x600x700mm, very rough thats very off the cuff but those are the numbers that come to me, take that with the appropriate grain of salt.
Sounds like the kind of project I should have dreamed up, i hate you! BTW, im always around for VH info, im ultra easy to get ahold of (phone, email, AIM, whatev), so theres no excuse for lack of information here.
