brycity wrote:Next I read on Ellizautoworkz that you need to do some modifications to the following:
Engine cross-member Frame rail Tension rod bracket Brake booster re-location
and you need to adjust your steering rack.
To answer these...
No - No mods needed at all
Depends - If I choose to use the VH Alternator I will need to modify the framerail, if I use the KA alternator with a custom bracket, I won't.
No - No mods needed
No - Stock booster in my car in the stock location, however if I want to change the #7 spark plug I need to pull the booster.
No - Steering rack is in stock location.
This is all in my S14. My hood closes and I'm using the stock VH Intake Manifold and an unmodified VH waterneck. I did need to cut the stucture on the underside of the hood for clearance, but if fits with about 1/8" of clearance between the hood and the top of the motor, and 3/16" of clearance between the pan and the framerail. My car has solid mounts so I'm not worried about engine movement. Also, to make the stock waterneck fit I needed to lower my crossmember by 1/4" with some billet spacers I made. My car is a 100% drag car so I'm not worried about the geometry of the front suspension being altered.
My Z on the other hand... that's a whole different story.
