I have a problem with a VH41DE cas.It was damaged due transport and is almost impossible to find another one.
The disk is damaged and the disk reading sensor also.What i need from you guys is to open a vh45de cas or a vh41de y33 cas and let me know if the disk is the same (i am almost sure it is) and the code from the reading sensor is also the same RSB-14 1Y11.
If i know it is i can buy any vh45de cas (easy to find) and repair my cas.
