THe runner length [from valve midlift point to entrance to plenum] is what primarily tunes the rpm at which the torque peak occurs. [assuming 2nd mode]
To get a lower torque peak rpm you need longer runners.The plenum voume primarily sets the rpm HP peak rpm along with the runner taper [diameter at top vs diameter at last round portion past injectors.
The volume of the runner must be larger than the cylinder volume [562cc] to get the extra boost [in volume] as the reflected wave from the sudden enlargement of the column at it reflects of the air mass of plenum.
The plenum volume must contain enough air to feed the runners without going dry at max rpm [or max flow] usually just above the HP peak rpm.
Anyway the exotic Q design was necessary to boost torque at 1500, 2000, 4000, and 4500 rpm then to provide a tiny increase at 5500 and 6,000 rpm................very complex design to squeeze the max out.
Obviously the harmonic frequency of tune [2nd, 3rd, or 4th] results in different runner lengths but the 2nd harmonic [reflection] creates the most ram effect and this declines as you go to higher orders [modes].
http://mgcgti.clarkeandclarke.co.uk/Page28.html
http://www.mne.psu.edu/me415/f....html
http://www.eng.ed.ac.uk/~jchic...7.htm
