Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu Dec 29, 2005 2:45 am
The headers are designed the way they are to accomplish QUICK cat light off to meet emission standards. Changing anything from the last cat back to engine is a violation of Federal and State laws.
Measure the backpressure at the first O2 sensor bung* to determine which might help more............exhaust, higher flow but limited life cat, or manifolds.
The exhaust cams are probably more a limiting factor than the manifolds.
Again the design is there to make sure the CATS function to at least 100,000 miles as required by EPA.
* Graph the pressure rise vs RPM at WOT under acceleration load to redline. You will see little until you start to exceed the torque peak rpm.Modern engineers try to achieve maximal torque [efficiency].
The rise in pressure is the converse of a flow bench test but very useful.
