Mettler wrote:Thanks sijoko, I have a pair of manifolds in my garage too... I don't want to use the measurements from them because they're inaccurate though.... I want to make my plates an exact fit & also have the ports line up perfectly.
Or do you think it's fine to use the factory manifolds as a basis from which to measure ?
I might just have to pull my motor out and measure it up I think, not much choice otherwise !
Hmm, strangely yours look like different manifolds too... I don't recall mine having elongated ports, nor being the same shape as those.
Since you have an extra set of manifolds, then I would use them for the flange measurement. Once you have the new flanges made, you can gasket match the flanges and the exhaust ports. Either way, the mounting holes on the flanges would have to be oversized or elongated to allow for expansion of the headers.
As far as the difference between the one I posted and yours, maybe it is due to the VH41 being available on different vehicles. I know the engine was available on the Cima and Leopard J. Ferie. Maybe other vehicles too. So that might account for the differences.
- Siju
