VH41DE coils and plugs
shaggythakidd
Car: 1999 Infiniti Q45t 119k miles VH41DE
Going to go and replace my ignition coils and spark plugs, what are recommendations for city/hard driving on a daily level. 99 q45t. Any advice appreciated
MowgliCSM
Car: 99 Q45t, 07 S550, 89 Mitsu Mirage Turbo.
In my experience, NGK Platinums PFR5G-11. Leave them alone out of the box, don't gap them. Get them from a reputable source, fake NGK's are floating around. Hitatchi coils. Cheap no name brand ones can cause funny issues.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
MowgliCSM wrote:
Sun Mar 20, 2022 2:06 pm
Hanshin (actually a China partnership with Denso) is okay for coils too, they actually make the majority of Nissan COP's these days. But @MowgliCSM is right about going China-cheap on coils, don't go there. That goes for cam/crank sensors as well. There are lots of parts on the car where cheap stuff will work fine, but not those three.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
I would suggest you plan to do at least the passenger side valve cover gasket since you have to remove the coils anyway to do that job.
But why are you replacing coils? Are there intermittent misfire symptoms?
shaggythakidd
3Q Jay wrote:
Sun Mar 20, 2022 8:41 pm
ive been reading through fourms and found that dancing idle and a few other issues ive had (P1320, trac/slip light coming on) can be caused by a malfunctioning coil, among other issues (egr, plenum gasket, cracked line, or a MAP/BARO solenoid switch) all things i plan to address when i do the plugs/coils as i want to do a refresh of what i can afford at the moment and get a better understanding of how my motor works. valve cover gaskets is probably not a bad idea considering the gunk on them and the engine itself. Thanks for the plug and coil recommendation as well.
heres a video of my issues https://youtu.be/1XE5rb3ENuw
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Lifetime replacement guarantee is a win and they will be genuine.
