Thanks Darin. I appreciate your comments here
Do not really have a hell of a lot to ask you to be honest! I've had a good read of Nico, your threads, a few by Justin and have spoken to Tim (kens son)= its all pretty straightforwards.... Especially since theres no cab on the thing.
Remote mounting the oil filter should be no big deal considering its got the offset mounting block. I did a very similar thing to a toyota 3vzfe v6 a few years ago- cut the mounting block in half and drilled and tapped the ports for barbed fittings. It worked very well.
ooh, found a pic even
I've given up on the ORE project thread. Obviously im too open, vocal and everything else. I've created a monster there which I wont provoke again. I understand now why SO many people have told me they wont have project threads there.
changed to the v8 for a few reasons. I always wanted to consider the vh but cost was prohibitive for me. Time has passed and so the budget has been extended.
I also did not want to bother with the complexity of it all... but again- since the truck is sitting there with no cab there is not a better time for it.
There was one other reason for both the new cab and the v8 swap. Because the v8 is shorter than the 4.2 straight 6 I'm able to better position my cab further rearwards. This means I no longer have to take a massive slice out of my body (as i see you have done!) and I can keep more of the (nicer, later shape) interior, dash/carpets etc.
Its all coincided to make a much better vehicle I think. Cant bring myself to be enthusiastic about anything that i know I could possibly do better.
I'm not too well at the moment. Have not been at work for a while so am unsure if I can make it to the manakau event HOWEVER I'll try. Would be good for me to get out.
I do remember you like green bottles.
ALSO. I've got myself a good VH45. Oh happy times. ECU, loom, auto trans etc. Have also contacted that wholesale place in aus and will likely order one of their manual shift valve blocks (unsure still as to why it has wires and solenoids in it? in their pics) I'll get a local trans shop to put the Q45 internals into my safari box. It was due for a rebuild anyways.
re: the m90... have not put much thought into it. People use the M90 on the 1uz without problems and im only wanting, say, 5psi so issues should be limited. Its in the future so will think more about it then. If not the M90 then the m112?
Thanks all
-Nathan
