Infiniti BRAND is/was not sold in Japan. However the first generation Q45 (with the VH45DE) was sold in Japan as a Nissan model but with all Infiniti badging unchanged (although they were right-hand drive). So you could indeed get a JDM VH45 with an Infiniti logo on it.ZX2NV wrote:not even sure if they are true USDM as they sold the infinti brand in Japan too didnt they or was it strictly a US sales pitch branding.
Gday DoctorcheeWith your adapter plate gearbox conversion did you have to extend the ball pivot on your clutch fork? Due to the gear box being pushed back because of the adapter plate? Or did you use a spacer on your flywheel?The problem i have with my adapter plate conversion/VH41/RB gearbox, is the clutch fork is floppy and not hard against the pressure plate and ball pivot. In fact when i tried to bleed my clutch (brake fluid) the piston popped out of the clutch slave cylinder as the fork didnt butt up against it.Bartdoctorchee wrote:what i have done is only a VH41de -> RB25DET
Mettler wrote:Just extend your thrust bearing. Make a spacer sleeve for it.
Will do. Ill add some pics of it.Mettler wrote:Hey Bart, I'm not sure specifically how my thrust bearing was modified (I didn't do the mod to it), but mine has a steel spacer fitted between the fork pressure surfaces and the bearing, as shown in the attached pic... it seems to be just a piece of thick walled tube, or roundbar with a big hole through it. It doesn't come apart by hand, as though it's been press fitted on or something.
I think 6061 aluminium would work fine for this since the load goes down the length of it, it shouldn't break if you're generous with its thickness.
Keep us updated how you go
