The Cima is Y32, not J30. The front subframe bolts up in four places, is it like that in the Z?optimul22 wrote:So i want to do a vh41de (jdm) z32 swap. then stroke it to a 45 (easier fitment hopfully and acc. arent as big of a pain from what ive heard) does anyone know if a j30 crossmember fits in a z32? i know that the cima(j30) came with the 41 and was hoping this would work.
Yeah I'm designing the flanges at the moment. I tried modifying my alloy sump by cutting the step out of the middle and having plate welded in, but it warped it to s***, so now I'm going to make a whole custom steel sump. When I finish the drawings I'll send you them so you can use or modify as you please. I expect to finish the design in the next few days.optimul22 wrote:if that doesnt work is anyone making a custom oil pan that i could get the designs off of? i dont want to franken pan mainly because for me it would be easier to fab one up then to smash two together if you know what i mean. i can do motor mounts easily but then my other question is if anyone had any ideas for custom intakes. ive seen a few on here but no real technical specs and it seems everyone is running away from dual TB's. Im not sure on my plan for that yeat but i want all the info before i go ahead and down my summer car for 5 months ( ill do the fab work prior if possible)
Thank you for any help!
Yes, 4 studs from the chassis into the crossmember. I'll probably have my crossmember off this weekend if any piccies and dimensions are needed.Mettler wrote:The Cima is Y32, not J30. The front subframe bolts up in four places, is it like that in the Z?
Ironically I've had a USDM VH41 sitting in my garage for a couple years now. Someday I might try to throw it into something. The USDM VH41 and JDM VH41 have more similarities than people would lead you to believe, just as an FYI.optimul22 wrote:Superhatch thats exactly what i think i needed to hear just a kick in the a$$ to get going. im almost ready to start i just need to make sure i can get a quality engine then ill start immediatly
tmorgan wow that thing looks bullet proof did you have any issues with leaking? if you remember who gave you the design let me know
Do you have Solidworks?optimul22 wrote:mettler that would be insanely cool of you to do that thank you im trying to be the first one in utah with this set up just so i can smoke the rich pricks and this set up would be amazing
Don't you mean Y32?SuperHatch wrote:If you find a good source for JDM 41's let me know. Thats the motor we should all be messing with. If you find one out of a FGNY33 Cima, I'd be very keen on acquiring it.
Yes, you are correct, I meant to say FGNY32... the AWD Spider Mani 41. I'd love to find one... Called every importer in the states that would actually talk to me and none were willing to try to get one. I even said I'd just wait until their next container was coming and buy 3 or 4 of them. They didn't care... I would think that if someone was willing to guarantee 3 or 4 engine sales in your next container you'd be willing to work with them. My mistake.Mettler wrote:Don't you mean Y32?
The japanese Y33 is like your US version, without spider manifold... like out of this: http://www.trademe.co.nz/Trade...0.htm
Yea just a bitMettler wrote:That's gotta piss you off...
Thats a smokin deal...Chrispy300 wrote:Wow that sucks...
Over here they will source particular engines for you no hassles. There are quite a few companies that specialise in brokering items from Yahoo Japan. I've got a mate here that sourced a JUN 3.2L stroker VG30DETT with HKS 2530's all delivered for under $5k. The stroker kit alone was worth $10k...
You'd actually be the second in Utah, well I guess first VH41 Z32 will be your honors, but I had the first VH45 swapped S13 in Utah.optimul22 wrote:mettler that would be insanely cool of you to do that thank you im trying to be the first one in utah with this set up just so i can smoke the rich pricks and this set up would be amazing
Sure no probs, I'll send you the completed design. I've nearly finished it, trapdoor sump design.CrazyTrance wrote:Is this flange similar to the vh45 flange? I'm looking at it and the design looks similar but some of the holes look to be in a bit different place. Any chance you would be able to send that file my way as well?
That would be AMAZING. I'm working on making a new lower profile but wider sump of my own. Would be interesting to see another persons design.Mettler wrote:Sure no probs, I'll send you the completed design. I've nearly finished it, trapdoor sump design.
