mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Sat Mar 21, 2009 4:54 pm
Long story on how it all happened but basically I've got a nasty ticking noise. I heard it coming from the right head and not the left so figured some air got in the hla's. Took it all apart, bled the ones that seemed bad, put it all back together and... the ticking noise was still there. So, I took it all back apart again and decided to bleed every single one in the right head. Winter was coming so I didn't get to far and started again this week. Bled them all, put the valve cover back on without silicone to try testing it out again and they still ticked. Took it all apart yet again and completely replaced all of the hla's with ones from another VH I have that I know were good. Bled all of those before putting them in, put the valve cover on, and yet again they ticked.
After that I got out the stethoscope and listened again. I heard the ticking in the right valve cover and the block which then made me think bearing, however, the left valve cover was completely silent so I'm at a loss. Before starting the car I pulled the fuel pump fuse to build up oil pressure while cranking. Cranked a little bit after the oil light turned off so went ahead and started it. On top of the ticking the engine has a hard time running, acts like it has a heaving miss vibrating very poorly, and tries to die unless I give it some throttle. The ticking is relatively even but sometimes ticks unevenly as well.
Any ideas?
