Don't quote me on this but didn't some j30 (leopard j ferie) in Japan come with vh's?kbflip02 wrote:curious on everyones input on this....as well as what might be needed to get it done...all input would be greatly appreciated...-K
its nearly impossible to find pics but it was called the nissan leopard J ferie type X and came with the VH41 and a 4 speed automatic transmission similar to the early model Q45s...it also did in fact come withe the front chin spoiler....if you check japanese websites you can find one unfortunately i dont speak japanese...you can download a language pack so i can translate to help too...craigztoyz wrote:Thats what he told me on the phone the other day too. But I have never heard of a J45? dont know what they called it if they did make it. I plan to make one soon, but have not seen a pic of one from the factory. If so, Probably only an automatic car.
Yes, it was offered with a VH41DE ... I'll see if I can find some specs somewhere.thejapino wrote:Don't quote me on this but didn't some j30 (leopard j ferie) in Japan come with vh's?
Keep us updated my good man!!! If it bolts straight in that'd be awesome!!!!efeezie wrote:I have a J30 and Im about to start on this exact swap this weekend.
I took a few measurements and half *** sat the VH in the J30. It appears as if it will bolt straight in just by rotating the VH mounts 90 degrees. The frame "might" have to be notched to clear the alternator but I'll know for sure this weekend
And the J30 rear diff will hold up just fine, I made 725whp through a good ole' r200 diff.
been searching for that thread about putting 240 suspension on a J but cant seem to find anything informative...just that people have done it but dont explain how you know...personally id only want to lower the J about an inch to an inch and a half all the way around.....also the J sits level as is so if you took 300lbs off the front i wonder if it would sit higher too...elwesso wrote:
J30s only weigh 3500lbs curb weight, so a 3200-3300lb 4 door sedan with an *ahem* interechangeable suspension wiht 240sx is really appealing!
Were you using the stock ones with the cushy liquid filled mounts? Could you possibly use a hybrid between the J30 and Q45 mounts to get it to sit a little lower? Are you sure that the motor sits too high, or is it that the motor is too tall? It might be better to deal with hood clearance than to have the engine/trans sit goofy..efeezie wrote:OK got the motor dropped in and just as I thought it bolts straight in simply by rotating the mounts 90 degrees. However the motor sits about 2-3 inches too high. So it doesnt clear the hood very well. I'll probably make a custom set of mounts so the motor will sit a little lower.
The lower sway bar is also in the way so it will probably be tossed. Maybe a custom sway bar later. The AC compressor and PS pump hits it.
The oil pan has TONS of clearance which makes since because the VG pan is kinda bulky.
elwesso- I can check the torque converter fitment for you but Im guessing you would have to redrill the flexplate.
As far as 240 swapability the S14 suspension looks pretty close. I'll pull my S14 suspension out and check. I'll try and get some pics up as I move along.
YUP!!elwesso wrote:let me ask another question, when you put the motor in did you put it in with the factory exhaust manifolds?
