mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Thu Oct 12, 2006 7:23 am
What he said was right. The pressure in the exhaust system before the turbo is much greater than in the intake so exhaust could get back in to the intake. That's why turbo setups like having low overlap cams to deter that.
If going N/A, the opposite is true. You want some more overlap and if done right, the exhaust can actually cause a sort of vacuum in the chamber, sucking fresh air in. This is how its possible make the volumetric efficiency of an N/A engine hit 100% and more.
