To stop the head loading up with oil you could use a scavenge pump right? Scavenge from the head to the sump?CrazyTrance wrote:I would tend to agree with them needing to be opened up a bit for abuse. I've got two engine's i've acquired that i haven't taken apart yet, but both have spun bearings from high rpm abuse. Only makes sense, along with the head getting loaded up with oil...
We need someone with cash and balls to take these engines to the limit, Nizpro has done such extreme things but it’s not like they’re going share their R&DMettler wrote:Hmmm, getting ideas for a new sticky thread about recommended reliability mods for VH engines to be thrashed.
I'm running standard size big end journals and standard size bearings, I bloody hope I don't end up spinning any, seriously can not be bothered with another rebuild. lol
Darinz, any way to get a link for those different size bearings? That would be great!darinz wrote:I haven't done it yet but apparently there are 4 different size bearings for the VH available in NZ. My plan is to pull the crank and get it ground udersize to open the clearances and allow more oil in. That seems to be the key to getting them to survive when offroad.
A certain jetboat owner here in NZ has... it was previously 830HP NA, and is now twin turbo and putting out around 1500HP.Bart wrote:We need someone with cash and balls to take these engines to the limit, Nizpro has done such extreme things but it’s not like they’re going share their R&D
Yesvery good point, i think i know who you mean, he posted here couple of times.What his contact details? He would be good to get in touch with.Mettler wrote:A certain jetboat owner here in NZ has... it was previously 830HP NA, and is now twin turbo and putting out around 1500HP.
$$$$ lol.Bart wrote:To stop the head loading up with oil you could use a scavenge pump right? Scavenge from the head to the sump?
Be careful lol. On the engine's i have I believe one of them happened after the guy went over some rumble strips on a track and banged up the pan. The other one he said only lasted about 10-15 minutes of abuse...Mettler wrote:I'm running standard size big end journals and standard size bearings, I bloody hope I don't end up spinning any, seriously can not be bothered with another rebuild. lol
Drag racers use them to maintain oil pressure during launch when all the oil is climbing the up the inside walls of the block, autocross guys use them because of the numerous abrupt hard turns, which send the oil away from the oil pump pick up. Circle track guys use them as a poor man's dry sump to save their expensive engines.kingkilburn wrote:Accusumps can be used to boost oil volume and pressure when for what ever reason you lose either.
