SuperHatch »
https://forums.nicoclub.com/superhatch-u50790.html
Mon Dec 15, 2008 7:47 am
The other consideration is the intended usage of the car.
With a street car there is a lot of airflow through the radiator with extended part throttle low RPM operation. Occasional full throttle usage...
In my case, I get part throttle high RPM for a few seconds during burnout, then full throttle usage for 12 seconds, then idle for a few minutes, then repeat... the fan is my only true airflow between runs, I need to use as much of the core as possible.
