Dammitboy wrote:Well, if one was to convert to solid lifters on the VH, I'm assuming you'd need solid cams, & a way to adjust lash?
If you get the type of solid pivots that the shims go inside the pivot, they should work on the VH (I think the HKS ones are like this. The Tomei ones, on the other hand will definitely not work as there won't be any way to adjust them.
I have not tried this on the VH pivots, but with the SR ones, you can take the pivots apart and throw a couple of RB26 shims that are milled down to the correct thickness to make your own solid lifters. It's a lot more cost effective than buying FOUR solid kits for the SR (remember, the SR only has 8 pivots compared to 32 for the VH)
Then there's the question you had about the cams: Are the rocker arms are strong enough to take the abuse of cams designed for the hydraulic pivots. (the ramp is more aggressive for hydraulic cams)
