VH45 & VH41 heads are not interchangeable. To my knowledge, the Y33 JDM VH41 is the same as the USDM VH41.koukimatt wrote:Are VH heads interchangeable? I know that the early JDM VH41 uses 2-row timing chains so it may only work with the matching heads. What about everything else? For example, USDM VH45 heads on USDM VH41 block.
We pretty much established that none are, because the Z33 350Z gearbox pattern is actually quite different to the VH one. Where do you get your information from?koukimatt wrote:Which VH blocks are compatible with the Z33 350Z FS6R31A 6-speed manual transmission with no adapter plate? All VH41 blocks?
The main bearing beam actually bolts up under the main caps (i.e. is separate to the caps), and the Y33/USDM VH41 is the one missing it... the rest have it. It may be possible to bolt one up to this engine, but then you'd really want to be asking yourself why you're bothering with this inferior version of the engine in the first place.koukimatt wrote:Which VH blocks will take the main bearing girdle? All of them?
Here on Nico actually; I lost the link to the thread, but you guys were discussing VK/VQ transmissions and someone observed that the (JDM?) VH41 bellhousing pattern appears to be identical to the VK's.Mettler wrote:We pretty much established that none are, because the Z33 350Z gearbox pattern is actually quite different to the VH one. Where do you get your information from?
My idea was: If there is a VH block that shares the 350Z 6-speed bellhousing bolt pattern, then get the 6-speed, get a compatible block, put a 4.5 L rotating assembly in it, and come up with a twin turbo setup for my S14. I would prefer to use the better heads and the main bearing beam if available; I knew that some of these parts were interchangeable but I didn't know exactly which or how.Mettler wrote:The main bearing beam actually bolts up under the main caps (i.e. is separate to the caps), and the Y33/USDM VH41 is the one missing it... the rest have it. It may be possible to bolt one up to this engine, but then you'd really want to be asking yourself why you're bothering with this inferior version of the engine in the first place.
I remember the thread. Yeah it was discussed that the VH & VK have the same bellhousing bolt pattern... but we also established that the VQ 6spd transmission is not compatible with the VH or VK by finding one for sale on ebay and analysing the pictures which clearly showed a different pattern.koukimatt wrote:Here on Nico actually; I lost the link to the thread, but you guys were discussing VK/VQ transmissions and someone observed that the (JDM?) VH41 bellhousing pattern appears to be identical to the VK's.
Yeah it'd be nice to be able to slap a 6spd box on the back of the VH!koukimatt wrote:My idea was: If there is a VH block that shares the 350Z 6-speed bellhousing bolt pattern, then get the 6-speed, get a compatible block, put a 4.5 L rotating assembly in it, and come up with a twin turbo setup for my S14. I would prefer to use the better heads and the main bearing beam if available; I knew that some of these parts were interchangeable but I didn't know exactly which or how.
If the VH isn't directly compatible with any manual transmissions, I can live with that. I would prefer to get an early JDM VH41 as you have done, but since getting one to the USA will be painful, most likely I will source a 1994-1995 VH45 locally -- the timing chain guides were upgraded to metal for 1994, so that reduces the chance that I'll get stuck with a trashed motor. For the transmission, I'll just get an adapter plate or hack the auto bellhousing like everyone else.
word, i paid $200, its a little noisy and 4th is a little grindy when you're power shifting but other than that its solid...LEMHEAD16 wrote:I paid 275 for my Z32 transmission. Why would you want to pay $600
What flywheel/clutch combination do you run? I've got a Z33 with a VH45 on its way and im a bit confused with all the Z32/Z32TT flywheel, clutch/flywheel spacers/starter ring combinations there iscjmirabal1 wrote:I'm running a vh with a 370z 6speed. Adapter plate made it possible.
And these are a lot steonger then the 350z 6speeds
