elwesso wrote:
In order ot do any real good cam work, we need to upgrade the valve springs... not a big deal since we can use the GTiR springs or whatever spring combo you have... Valve springs shouldnt be a big deal...
gtir inner springs will be okay for a cam with stock lift but more duration, but for a cam with .450-.500 l ift you will need to get springs that will allow more lift because the stock VH springs have a max lift capability of just under .400" lift before they reach solid height.
Quote »assuming we have enough clearance, we would want to make lift on the intake cam .450-.500"... I assume we leave the exhaust cam stock, or do we make it with that lift as well... we also want aout 30* more duration, [/quote]both the intake and exhaust would be ideal, but they don't need to be the same. The exhaust cam for a n/a app usually has a longer duration and lift than the intake side. So, the more aggressive cam in a n/a application would need to be the exhaust cam.
Quote »How would this effect things like idle and overall smoothness...? Woulldnt you think the intake would be pretty good as it is, or were you just referring to a CAI or something like that..... The stock TB is good to big HP....[/quote]I'd say the stock intake manifold and TB will work as good as any, because there are no major flow restrictions and it's an overall good long resonance design. The only thing I can think of that would help on the intake manifold is for it to have a larger plenum. Usually, on a n/a engine you want the plenum volume to be 100% or 2x larger than the engine displacement. For intake, I would look into just getting a nice 90mm short ram tube with the maf on the end.
A cam with more overlap and more lift will be a little bit more rough, but it won't sound like a bigass bigblock race car. A mild cam like we're talking about will be enough to where you shouldn't feel or hear that much lope, but it won't be as smooth. It will be rough, but still run good and give decent vacuum. It should still run on the stock ECU since it's maf based. map based ecu's have a harder tine controlling fuel because the low vacuum signal makes the ecu think the engine is under load. Quote »Would this cam setup work well with a boosted setup... I assume with boost you would need even stiffer valve springs...[/quote]What we're talking about is strictly a n/a setup. For a boosted setup, you don't want any overlap at all and you want to match the cam duration and powerband with your turbo compressor map.
Quote »Also, how will this work with the stock ECU, or stockish ECU? Will it need to be changed in order to work properly??[/quote]It will run okay as-is because the ecu is maf based. It will need to be tuned to work properly and get the most power for sure but it will run with no modifications.
Quote »IM sorry for all the dumb questions, but this intrigues me... It seems possible to make 350+ish HP on a N/A and fairly stock motor (stock short block and stock intake manifold)...[/quote]I don't mind at all, I love spreading knowledge and edjumukating people.I bet with a nice set of healthy cams with the right valvetrain, a true longtube header system, an intake manifold with a 8L plenum, and a good ECU tune 325hp to the wheels with a flat powerband all the way up to 7500rpm will be a piece of cake.
Modified by defrag010 at 10:02 PM 7/10/2006
