VH 41 carb manifold and dizzy where and how to??
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
loosecannon
Hi, Thinking of putting a VH41 in a boat, does anyone know where I can get a intake manifold for a carb setup??, and how to set up a dizzy ( like a Mallory) just to make it a simple setup
or point me in the correct direction
Thanks in advance
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
It would be easier to keep the fuel injection. I could 99.7% guarantee there is not a carb manifold for a vh41, unless it was a one off you found.
There is no easy way to run a normal distributor on one either.
If you are wanting to keep it simple, run it injected.
IF you decide to build a carb manifold keep us posted. I am not that familiar with boat motors, is there any reason it is better to run carbs on a boat?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
i agree, you would spend WAY less time keeping it fuel injected. The stock ECU can pretty much be like a "standalone", in that it only needs power to operate the engine, and you can bypass most of the emissions stuff without any issue.
just out of curiousity, what kind of drive setup were you gonna go with...? An I/O sterndrive or an inboard?
loosecannon
Ok, where can I get the info on how to power up the ecu, pinouts etc, etc, I'l have a look at it
Chrispy300
Car: 1993 J-Spec 300ZX 5 Speed Slicktop
Pretty much just go through the wiring diagram. It's actually reasonably simple...
There is a copy in the Factory Service Manual available on this site somewhere.
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
There are a few different types of carb manifolds available for the VH41DE in New Zealand.
Keep your eyes open on http://www.trademe.co.nz or contact Brian Hartley at the Head Shop in Palmerston North, he sells his own carb manifold design for the VH.
loosecannon
Yeah it looks like the kiwi's have the good oil on setting up theses engines for a carb setup for speedway
any links or contact details for suppliers down there?
Thanks again
robb1971
Car: 1971 ford falcon
I have seen 2 different intake manifolds, one using quad webbers and the other set up for a 4 barrel holley, on NZ motors . the dizzy is run off the r/h exhaust cam shaft and sits in the front of the engine . Any engineering shop should be able to sort it . Or you could use an electronic unit with crank or cam sensors.. lots of options really... but they all cost . Personally I would stick with the stock system.. shame the stock manifold looks dumb
pinkytamz1977
Car: nissan safari 1987 fitting a nissan vh41de any day now
yep its good to be a kiwi but i still want to keep the factory set up i have had a look at the wiring diagrans but what one do i use as the donor car i brought is running like a bag of s*** and is now hard to start and No. 2 wont fire any help would be good
Return to “VH45DE / VK45DE / VK56DE Forum”
