i keep hearing about this phantom of a motor(VG38), where is it possible to get the pistons needed for it?? how much for something like that...???
what else would be necessary for that big of displacement?? MPFI with higher flow fuel injectors? is TBI out of the question? and what about head work and air flow?
which rods would you use? i imagine the VG30DE/DETT for the added strength....
i have tried ing. i have read every single thread i could find on this subject so far... looking for more answers...
my other option is the VH45 piston setup.
here going to go the VH45 piston route. ...
http://www.motoiq.com/magazine_articles ... vg30e.aspx
And getting the heads ported... seem like that is a necessary/beneficial upgrade to do? estimated cost to do this port job would be ???
http://www.motoiq.com/MagazineArticles/ ... dwork.aspx
will all of this be ok to run with my TBI intake??? or are the two ideas not compatible.?
if not i guess i will be going back to my original plan of MPFI. with obd1 ecu.
which would be less work and more of a bolt on upgrade? more money??
i wish i could find just one person that has a VG38 at least so i know that it is doable. cause so far all i have heard are rumors.
