vg33er
pathfinder_se_black
Car: 2000 pathfinder, FG2 civic si
does it have the same transmition as the vg33e?
nissandoms47
Car: 2002 Nissan Pathfinder SEV6-Custom 7" lift-33-1250R15 BFG KM2- a bunch of other s*** i cant think of
yes.
pathfinder_se_black
what parts differ on the motor besides the supercharger, injectors, and manifold? does it have a different compression ratio?
tmorgan4
Car: 2000 Nissan Pathfinder
Yep, lower compression on the ER.
pathfinder_se_black
tmorgan4 wrote:Yep, lower compression on the ER.
i guess its not worth doing a conversion then right?
nissandoms47
it shouldnt really matter if your just wanting to put the ER intake and all that on. i dont know what you would do about the pulley setup tho.
pathfinder_se_black
wouldnt i have to put a different pully set up anyways?
nissandoms47
probably not, just get a longer belt unless the supercharger will be offset from the crank pulley, then your in trouble. but you'll need to convert to the ER harness and ecu and probably even the trans harness and possibly even the gauge cluster.
pathfinder_se_black
yea i know about the ecu and things, its alot of work.
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
It doesn't seem like as good of a bang for the buck swap as I originally thought it'd be, but it would be cool to have a S/C QX4 I'd have to have a hole cut out of my hood tho. .
pathfinder_se_black
KoukiS14 wrote:It doesn't seem like as good of a bang for the buck swap as I originally thought it'd be, but it would be cool to have a S/C QX4 I'd have to have a hole cut out of my hood tho. .
yea i looked at all the set backs and its not worth it but it would be pretty cool.
nissandoms47
lol its not a setback for me really if i chose to do it. ive replaced my engine harness like 3 times. ended up not being the wiring at all. i think it would be cool to put a different supercharger on there that didnt need all the stock xterra s/c ecu and wiring. maybe like a powerdyne or something. i think i saw a s/c qx4 on cardomain a while back.
