VG33E with VH45 Pistons
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
http://forums.maxima.org/showthread.php ... fi...79873
I wonder if you could get oversize pistons for a VG33E and put them in a VH45 for lower compression?
The point is we know the VH45 has a 93mm bore, the VG33E has 91.5mm...
T45
Car: King Kong powered Z32
Why not just put 41 pistons in the 45? Aren't they identical but only with the wrist pin moved higher up to shorten the stroke?
SuperHatch
Car: 96 TLC
T45 wrote:Why not just put 41 pistons in the 45? Aren't they identical but only with the wrist pin moved higher up to shorten the stroke?
The 41 location is lower, not higher. Not to mention a change that drastic would result in an extremely low compression ratio. It's good to think outside the box though...
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
6mm lower to be exact :p
doctorchee
Car: BMW 318IS
I heard VQ35DET pistons drop right in with a 9:0 compression....
got the information somewhere in here. but i am not sure....
elwesso
2007 BMW M Coupe
its actually VQ30DET pistons and no one has done it to be sure.
doctorchee
Car: BMW 318IS
likely i will try it.... but cash is running out at the moment...
properly buying 1 pc to make comparasion is good.
T45
Here's some great info on swapping Q pistons into a VG33 which is cousin to the VG30.
http://www.nissanperformancema...inder/
What about 45 pistons in the 41. What would that accomplish?
Mettler
VH41DE pistons have a pop up section on the top, unlike VH45DE pistons which are flat. This is probably what gives it that 10.5:1 comp ratio rather than 10.2.
Running the 45 pistons in the 41, You'd get an increase of 40.76cc combustion chamber volume at TDC due to the volume of the 93mm x 6mm cylinder shape that the compression height difference makes up.... plus the small CC difference between the two pistons tops.
Ultimately, I think this would decompress it far too much... can't be arsed running the maths but it'd probably be somewhere in the range of 7:1/8:1
SSDwellah
Car: '90 Z32 Coupe w/ VH45DE + 5-speed (FOR SALE)
'06 Infiniti G35 Coupe 6MT
'08 Frontier 4x4 SE KC
Changing the pin height does not change the stroke anyway. It just shifts the absolute minimum and maximum distances. Its analogous to changing the rod length. The stroke can only really be changed by making adjustments to the crank (machining the base circle smaller, rewelding the throws further out, etc...).
hannibal
Car: Red Line to Glenmont
From looking at piston mfg'er sites, I dont see anyone that makes VG33 pistons, much less oversized VG33 pistons.
SSDwellah
Yeah you would probably have to get super overbore VG30 pistons
alrighty
Car: 1970 240z
2003 fx45
Been running Chevy small journal rods in 2 vk45 motors for a couple of years now.One with forged coyote pistons(wiseco) and one with stock vq30 pistons.Rods are Chinese knockoffs with arp bolts.The machining is what kills you, even on a cheap rod.Have to get rid of offset,and narrow which the Chevy rods come out perfect for Nissan rods,then have the big end resized for the 55mm Nissan journal.This is an old thread but thought I would post if someone had any questions.
Gday
Return to “VH45DE / VK45DE / VK56DE Forum”
