DrivenDaily »
https://forums.nicoclub.com/drivendaily-u229824.html
Sun Jan 05, 2014 2:12 pm
Hey guys. So I just picked up a 97 QX4, 125k miles. Cosmetically in flawless condition. I previously had been a honda-head, in the performance scene for hondas, until recently the love of my life was stolen out of my indoor gated parking garage, and stripped to metal and wire.
About me? I worked as a tech at Firestone for a few years after getting my associates in Auto repair, now pursuing mechanical engineering, so the past year I'v been unemployed and away from the maint/repair scene.
I'm about to do a timingbelt/waterpump job on this vg33e, and I had a couple questions that haven't exactly been addressed after a few good hours of research. Can you experienced folks give me some insight?
-New water pump comes with studs. When I install these "studs", is hand tight good enough, before reinstalling the fan blade nuts?
-I'm not sure the compressor in my garage is capable of allowing my impact to run off that crankshaft bolt... just to verify when using breaker bar against the frame, engine operates clockwise from the front of engine, so i hold breakerbar under frame near RF wheel, correct?
-Is it possible to replace water pump with timing belt on? I was planning on pulling off the belt half way, cutting in half along the belt and installing new belt (assuming engine was in proper time). .
-how can i keep the engine from rotating when I reinstall the crankshaft bolt? I would assume its gunna wanna turn when I torque it with the wrench.
-How difficult would it be to pop off that harmonic balancer without a puller? I figured a rubber mallet could get it off, and I don't have access to a puller (without sourcing one from online).
Obviously this post is for more of the experienced folks, who could perhaps just give me some insight on personal experience with this DIY. Its obviously a job that shouldn't be f*** around with, as it can scrape valves/cylinders etc in the blink of an eye.. so I just wanted some verification before I jump in.
Please give me your educated opinions! thanks!
