VG33E in search for loving home (engine bay)
Discuss topics related to the VG and VE series engines.
maikan
Car: 1999 Nissan Pathfinder Chilkoot VG33E 4wd
I read a lot of topics for VG33
And I found here a lot of great way for unleashing the power hidden in these strong block. Ex; boring, supercharging, heads, etc...
But I want to know where I can put these motors. In what car will they fit?Am I condemned of using them in path, frontier, or can I put a VG33 in a Z32, Z31?
I have a VG33 stock out of a 99 path And I can put my hands on a 300Z 93-94 not absolutely sure yet. The Z is in great shape but there is no engine.
I could mod the VG33 and get the most out fo it, but before I want to know if the mounts are the same ? Maybe someone know if the size is OK for a 33 in a Z.??
Before putting money in there I want to know if someone think It can be done.
Modified by maikan at 9:19 PM 4/27/2009
cypherbane139
Car: 85 300zx
i'm sure you'll find someone on here that knows way more than i do, but ive put a few motors where they didnt belong before. what i always had to work around was the difference in wieght, the wiring harness, room, driveshaft (lengh and splinded right) and steering shaft.
before i did anything i had measured , extensivly. =) hope i helped a little bit
krdk
Car: 94 Nissan Pickup XE-V6, 98 Chevy Malibu LS 3.1
if you use the z31's engine harness spliced to the vg33, its a straight drop in. might have to change the pan, exhaust, TB, the usual. VG33 is a VG30 with a bigger bore and thicker cylinder walls.
vgterian94
Car: 1984 Z31 2+2 GLL 5MT Turbo-Conversion Grand Tourer Build
1985 Z31 2+0 GL 5MT Turbo Stock
2000 Outback Wagon 5MT w/ Winter & Sound Packages
VG33's are pretty much bolt-on in a z31 after you swap accessories and crankshaft:
http://www.xenonz31.com/vg33eswap.html
Not sure about the z32 tho /=
r200helical
Thanks for that link vgterian94! I knew I would find someone who has done it to a z31.
Return to “VG30 / VE30 Forum”
