mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Thu Jun 05, 2008 11:59 am
1A. The stock intake should work just fine. Stock, it is one of the best flowing intakes available on the SOHC VG. Port match both the upper and lower intake manifolds and port match the modified throttle body to the upper manifold and it should work great.
The problem with the manifold for the supercharged VG is that the supercharge itself is essentially the upper manifold. You have the lower manifold connecting both of the heads, then basically a plate that bolts to it, then the supercharger to the plate so it won't work as an actual intake manifold unless you were going to twin charge the engine (supercharger and turbo), which I don't recommend. Just stick with the stock intake and it should work just fine.
1B. When you go turbo, generally the manifold pipe diameter will be smaller than most NA setups would be (and probably even a supercharged setup). After the turbo, there's almost no limit. If you go single turbo... don't go any less than 3" all of the way back. Twin turbo, 2.5" from each turbo back should do fine.
No backpressure is needed at all. Its a common misconception that backpressure is needed for low end power. What is really happening is when you go to a larger exhaust you're basically just changing the tuning point of the exhaust. A smaller exhaust has great flow and velocity at low engine speeds but as the engine revs up it starts becoming more restrictive, increasing backpressure and decreasing power. When you go to a larger exhaust you gain your top end power back but sometimes the flow isn't quite as optimized on the lower end, which is why you can lose power down low with a larger exhaust. When you go turbo... this all goes out the window. You almost can't go too big on the exhaust with a turbo. Reason being, the less back pressure you have on the exit side of the turbo the quicker it will be allowed to spool. This gives you better low end power as you have more air, sooner.
2A. You can get larger valves, Ferrea makes 1mm oversize, stainless steel valves for both the intake and exhaust. I believe that's about as big as you can go without running into problems. Generally... I think a good port and polish with some good cams designed for a turbo setup will benefit you more. If you're going all out, it wouldn't be a bad upgrade but probably not absolutely necessary.
2B. Not much truly needed to be done here depending on your power goals... but after some recent discoveries there's actually a lot you can do if you want. Turns out, the VG33's have some super thick cylinder walls, about .300" thick. As a comparison, the VG30 has roughly .177" thick cylinder walls. This means, you could actually bore your VG33 out to around 98 mm and still nearly retain the same thickness as the VG30 cylinder walls. This gets you right under a 3.8 liter VG (3,756 cc to be exact).
You don't have to go that high, not by any means. Stock, the VG33 with boost is an absolute torque monster. I've seen one example making nearly 500 ft. lb. of torque to the wheels on a stock internal VG33 with a turbo. At that point, I'd probably consider going with some forged pistons. Stock size or larger, your choice. Either way they'll likely have to be custom so you can get them made how you want. BRC Performance is a popular company for the SOHC VG crowd for custom pistons. The most common route is to have them make the piston to your specifications based on stock, but with a larger wrist pin hole to match the VG30DETT rods. The DETT rods will bolt right up to your crank, no problem, but the wrist pin is just slightly larger in diameter. If you get your pistons made to use those rods, you could pick up an inexpensive set of Eagle H-beam rods for the VG30DETT for less than 600 dollars and would have a very strong bottom end.
As far as compression ratio goes, I'd keep it at 9:1 or less. Depending on your power goes, if they're somewhat high, less would probably be a bit better.
3. Here you first need to decide if you want to go single or twin turbo. Each has their own benefits. Single will be cheaper but depending on where you want it in the engine bay, exhaust pipe routing can get difficult. Twin works great on V engines as it reduces the amount of exhaust piping but it does, generally, increase the amount of intake piping quite a bit and you generally need about double of everything for it so they are a bit more expensive.
Once you decide which route you want to go there, we can move on to turbo selection. To kind of get that kicked off a bit... what kind of power level are you looking for?
Finally, are you interested in tuning it all yourself or having a dyno shop tune it or do you want a pre-programmed ECU? If you're interested in the tuning part of it, take a look at Nistune. Its pretty much the best, and one of the only, tuning setups for the SOHC VG ECU's. It gives you the power of a standalone for the cost of a reprogram and even some piggy back units. Definitely worth looking in to.
