VG33 heads+VG30? ?
Discuss topics related to the VG and VE series engines.
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
I bet this has been asked 10000 times before, does the water/oil pathways match,bolt patterns look to line up,looking at pictures.I ask because. I'm kinda in a dead spot with my r33.and had a frontier parts truck fall in my lap for 200 bucks. I mostly want to know is this even possible,would the head allow for more air flow. Or is it basicly the same a** a tt head,I know its a lot of questions. Thanks for your replies if any
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
I believe a couple/few of the water passages don't quite line up, but that can be fixed with a little dremel work.
Lay the VG33 head gasket(s) on to the block, and you should be able to see where a little grind work needs to be done to allow the water to flow through the passages sufficiently.
jbracy7
Thanks man,honestly never thought about that at all,I feel so newbish
Ozzie
'06 MK5 Golf tdi
It's not really newbish, it's just sometimes we all forget/or don't know a little trick like this.
And I believe this is what Nico is for... helping each other out.
Sharing info is free, but could help someone out a great deal :)
Interested to see if you go ahead with this, and how well it works out.
Maybe you could do a write-up, with some progress pics, and submit it as an article here? (That'd be kinda cool)
jbracy7
I Planing on doing just that
Return to “VG30 / VE30 Forum”
