halfyearD21 »
https://forums.nicoclub.com/halfyeard21-u83850.html
Mon Dec 17, 2007 4:53 am
if the smell is coming from the tail pipe check your entire air injection system, these trucks push air into the exhaust to finish burning the mixture. if something in this system is faulty it will make a rich smell in the pipes. i know this because mine is missing the AIV box, or whatever its called, and it makes it run rich as well. Might also run some injector cleaner through it in case you have a hung injector. The way i checked if my injectors were working properly was take the TB off the motor, unplug the coil, and have someone crank the motor over while you look at the spray pattern and amount. simple common sense will tell you if its dumping gas into the motor this way, it will be very apparent if it is a hung injector.But if you can smell it up in the engine bay you might have a leaky throttle body.Hope this helps
