evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Mar 02, 2009 10:15 am
I think you'll have an issue with the engine mounts, turbo and steering column
the VG trans shoud bolt right into your car with no issue, this will determine the engine location, the passanger mount might line up? I really ahve no idea, but shouldn't be too difficult to modify if need be, the issue is ont he driver side, if you get the satan turbo relocation manifold that puts the turbo up front you can run n/a vg driver side mount and then it might line up, or at least be as close as the passanger side
