jdmaddict1981 »
https://forums.nicoclub.com/jdmaddict1981-u148108.html
Mon Nov 23, 2009 12:10 pm
The idea was to take a 300zx (vg30dett) engine and place it into the engine bay of the pathfinder to make a v8 killer. one basic problem is that the downpipe from the turbo charger on the driver side would collide or not have enough room to go to the exhaust because of the connection from the steering wheel to the steering gearbox, an adapter can be fabricated or made to the downpipe to the exhaust which has to be a custom made exhaust system all the way to the catalytic converter. the same adapter has to be used on the passanger side turbo charger also (the only reason you have to use the same adapter is to equalize pressure from the exhaust across both turbo chargers so that one isnt outproducing the other). the other issue is where the placement of the o2 cencers should go. generically there is one o2 cencer in the pathfinder upstream from the catalytic converter to retain the usage of the o2 cencer stock you would have to create a y-pipe for the turbo exhaust system. the only thing that i could think of that would be a problem is the bolt pattern from the engine to the transmission. nissan is just like any other car company they are going to try and produce a basic setup for every model of that year using as many common parts as possible (i.e. starters, manifold gaskets, transmissions housings, engine blocks, etc.) im in the process of researching this by usage of haze manuals the internet and the fsm (field service manual) for each vehicle. so far, i have found that it in theory should work but in practice there will be fitnent issues if you do not have a working knowledge of vehicle wiring this would not be a good project for you to tackle. im gonna start my project in feb. the best way to do one of these projects is to take at least 30 to 60 days of research. flying blind on a vehicle build is always a bad idea. when i complete this project i will definatley post pictures and notations how to do this step by step so if you want to emulate my project so the headache work would be done.
