mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Fri Nov 23, 2007 2:29 pm
Yup, you should be able to put some different cams in there... you will lose the non-interference design though so be sure to keep up with the timing belt.
You can definitely twin turbo a VG30E, its just all custom fabrication. As for a reason why they didn't... I really have no idea. At the time, for the power they were making a single turbo was definitely more than enough so that could be it.
At the time, the twin turbo setups were possibly used for slightly quicker spooling. Probably the biggest reason though... for V engines twin turbo setups are a little easier to setup as you don't need a crossover pipe like on a single setup.
I believe someone is currently working on making twin turbo manifolds for the Z31's but I'm not sure if its ready to sell yet or not.
transmission wise you can pretty much use any transmission from the VG's, they all had the same pattern. The strongest one you can get is the Z32 5-speed. To make that one work on a VG30E you'll need a 89-91 Maxima flywheel, Maxima or 84-86 300ZX clutch kit, Z32 throw out bearing, and the Z32's starter.
Now, I don't know if anyone has done that transmission swap on a Z31 yet. I did it on my M30, which had the starter bolted to the transmission like the Z32 so there was plenty of room in the transmission tunnel for it. The Z31's starter is mounted next to the block so there's a possibility the starter won't fit in the transmission tunnel. You can modify the tunnel for it to fit if need be though.
You can also use any Z31 transmission. The 87-89 Turbo being the strongest. The 84-86 Turbo transmission is a Borg Warner T5. They are generally a bit weak but are used in so many different vehicles (most notable the early Mustangs) that there are quite a few performance shops that build the T5's up to handle some serious power. The 84-89 N.A. transmission is generally considered to be pretty weak but depending on how much power you make determines its life.
The 87-89 Turbo transmission tends to be a bit difficult to find but if you do, it uses a 250 mm clutch setup so be sure to get the correct pressure plate and clutch as the rest of the Z31's use a 240 mm clutch setup.
If you go the Z32 route, be sure to get the NA transmission as there is a very slight difference in the bell housing that will likely cause issues with the starter when you use the Maxima flywheel. I haven't confirmed this, but most say that is where the difference is between the TT and NA bell housings.
If you have anymore questions, don't hesitate to post them up!
