That does seem a bit high, especially since you are already using a thicker oil.So the often recommended easy fix ( go to thicker oil) wont work in your case.
It averages out to 1 quart per 1000 miles, which is considered the upper end of normal by most.
Have you checked for leaks?
Fred..
