mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Fri Mar 27, 2009 6:51 am
Pretty much your only options are with the transmissions available in the 89-94 Maxima's which include the automatic transmissions and the 5-speed transmissions. The 92-94 5-speed was on the VE30DE but the bolt pattern is the same, however, the axles and hubs are a bit different as the axles are larger. That transmission also had the option of being equipped with a viscous limited slip differential.
