MrEman »
https://forums.nicoclub.com/mreman-u132881.html
Sun May 03, 2009 7:20 pm
Sorry I was looking to deeply into the hidden meaning and thought you were mentioning a new database I hadn't tried to search--lol. Yes I have and that is why I am here asking. It is what is not said that I can't reason through. I've done a back door Hollander search via ebay auctions for various components as I don't have the $600 a year for the program to own my own copy.
There are inconsistencies in Hollander. The crankshafts are listed as totally interchangeable 93-98 as is the block , timing belt/gears. water pump,pistons, connecting rods etc. But I know t some time the crankshaft was modified for a larger snout but that could have been the 11/93 model change. The intake is listed as non-interchangeable but the gaskets are the same. The wheel hubs are the same 93-98 but the CV shafts are listed as non interchangeable between 96 and 97. The 94 transmission is interchangeable on Quest but not Villager.
Hollander doesn't state WHY it doesn't interchange but apparently does provide lots of inter-vehicle conversion information such as adapting a frontwheel design back and forth to a rear wheel application. Again the absence of 94 to 97 modifications is what is so wacky.
I just went to a junkyard where a 93 quest and a 97 Quest were available. The only two visually apparent differences I saw was the transmission oil pan and the intake manifold shapes.
I guess short of any known show stoppers I'll go ahead and get the 94 donor engine /transmission and just do it. One way or another we'll find out what the differences are that Hollander doesn't mention. I am hoping it was just owing to the crankshaft change for 96-97 and intake modifications and that, so long as I am able to swap external components and sensors, I can get on with the swap.
I've not even started to research transmission interchange but hoping that too was just a valve body performance mod etc. I figure with a 20k donor I'll at least have a good long block to work with but I'll not really know if it is a clean physical fit until I am bolting up the final nut .
Thanks for your input.
