DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Thu Mar 30, 2017 9:49 pm
Welcome!
First off congrats on the moxie to take this on yourself, and second for your choices of work, parts selection and the thought of doing it all right and at once.
That leads to part of my answer, which is actually to simply refresh everything and leave things as stock but to do some re-organizing and rethinking of a few things as you re-assemble and you should, as I have, get a better ability to get to everything you've worked on in the event a return is necessary. Probably less work than the coolant bypass and other relocates associated with that work. My Z guy has convinced me that time is in my favor, about 20 years worth (how long the car ran great with the original parts) and to keep that in mind when determining a course of action with the Z32- a notoriously over-engineered car from the standpoint of parts quality and performance in most cases.
So realize that
A) doing the right work with the right parts as you are and all at once, you may NOT need to return that deep in which case extra work may be wasted, and
B) anything that is modified has to be considered a failure potential, so really it's hard to see the mod being more than a removal/install aid rather than a good idea, or safer from the standpoint of a problem, and
C) plus that nasty emissions issue.
So I'd look at just doing some re-routes and maybe sensible replants as I have done to my TT, in an aid to repairs plus a cleaner looking bay but not a real tuck and no deletes.
I moved my PTU into the front of the car which helped in front of engine, and have removed the "looms" if you will that make such a mess on the sides of the plenum, redid that stupid IACV hose mess and the looping hose to the brake booster for WAY better DS access, and found easy ways to route those "loom" hoses and wires and more (rotated the turbo coupler bands, made a custom vacuum "tree" from the loom mess to bolt to a lower area and get those out of the way on PS, more small things like that) to better and out of the way places- I honestly now feel like it's looking into an NA bay until seeing the turbos and all of the intake piping end to end, MUCH unlike when I got her, and so often working on things isn't NEARLY the hassle of the first pass plus of course the practice of the past.
Not a lot of $ invested in the relocates and tidying, often adjusting OEM stuff and other misc parts, but I will admit to being a dressup junky though so I did go a lot further but just in that area with cost with a few dressups like throttle covers, SS bolts and Zspec washers, etc.
It's also pretty fun to do and plan, and not very fab intensive unless you want it to be, and everything looks better to boot!
