Tarnag40k »
https://forums.nicoclub.com/tarnag40k-u51051.html
Sun May 13, 2007 10:19 am
yeah if I had a 240sx (which I'm saving for) I'd have to swap a VG, I just trust the engine so much afer the **** I put my truck through with mine on several conditions, but then again that's the VG30E, not the DE or DETT, but I've even got stuck in a rivr had my truck pulled out after stalling and somehow start right back up, all pistons running, and no hydrolock, I was like, WTF but happy.
Anyways, you should be able to fit it in using the mounts to the V6 edition, and if needed the same oilpan incase the pans have a different shape. Since both are designed for RWD i Believe the bolt pattern for the transmission should be the same as on the V6 edition, so if you want to go 4X4 use that, I do not think the ECU could be used from the truck so a DE(TT) ECu will be needed, unfortunately after looking at Frontclips by Z1 I Can't say that whatever frontclip is bought will come with one, so It's best to purchase an E.C.U. core just incase.
Modified by Tarnag40k at 7:35 PM 5/13/2007
