s13sr20chris »
https://forums.nicoclub.com/s13sr20chris-u7880.html
Wed Jun 25, 2003 10:08 am
i dont mean to offend. you are clearly a person with considerable experience with the vg's. i am saying that in a technical sense the features of the later motor are better in my opinion. this is of course assuming that price is not so important. im sure price to hp could be plotted on a graph showing the per dollar efficiency of an et as compared to a dett, but by that rationale why not just got with a small block chevy? heresy. i have a lot of respect for the ol e. its still in current nissan lineups and i work on them everyday. just for the fun of it, let me respond to your rebuttal.
1)your right i believe i said that dohc is not necassarily better, but all things being equal(as in this case they almost all are) it is definitely better. hence the many advantages noted above.
2)you may be right when it comes to parasitic drag. i dont know for sure. i will say however that the natural inertia of those rocker arms(iirc they are like 2") will require stiffer valve springs and a lower redline for valve float control. i believe this will add up to a power loss. look at the domestics with their pushrod dinos. they lose big power just to the majorly stiff valve springs that they must use to control all that mass being actuated by the cams.
3)sure you can get optimal spark for a given combustion chamber using different plugs and gaps, but you will never be entirely optimal without having true crossflow. that is intake-plug-exhaust. on an et you have them arranged in a triangle sorta pattern(locating each object by its center would be a triangle). this simply is not optimal. how many ft*lbs is this good for? i dont know. i am simply dealing with the hypothetical question of what is better, capital notwithstanding.
4)i will have to divide this one up furthera)yes i am saying that a true crossflow head is better. i know the old L motors were great and all. please dont bring up nascar or anything. the general engine tech public has just accepted that this is true.b)yes, usually two valves will flow more than one. with the combustion chamber as a constant two valves will allow larger total area if they are maxxed out to the extent of a large single valve. this of course does not even consider valve shrouding, but only curtain area achievable. i have formulae as examples somewhere. i am kind of hoping i dont have to go looking for them though.c)i actually prefer a properly set up single turbo system to a twin. the problem here is that the z31 does not have a properly set up single. it has what i will refer to as "whack manifold syndrome". that is the turbo is way over on the drivers side with that long connecting pipe in between. that is not at all optimal.d)yes, i will not argue the cost to power of the et.e)yes, you certainly could achieve flow comparable to a modern, stock, dett head with a ported, polished, and larger valve equipped et head i imagine. this does not have any relevance to the arguement(err discussion) as i percieve it. as stated, i see this as a most power possible discussion and the dett head has way more headroom(no pun intended) than any et head. the kind of flow numbers available to a fully massaged dett head should(i have no first hand experience here) be way beyond that of the et.
5)yep, torque is the only number i am concerned with here as hp is just a function of torque and rpm. this is kind of an advantage to your side of the arguement considering the higher revving potential of the dett.
we are in fact talking turbos here, but not really. there are many variables that we could consider, primarily turbo choice and boost. personally i would not even start that discussion. i am only refering to the engine itself per se, not externals and accesories like turbos, alternators, or whatever. i am not grouping turbos and alternators together really. i am just saying that this discussion could really get out of hand if we start talkin turbo size.
no, never compared dynos first hand. you win in this respect.
6)coil on plug is better; we agree. the ign. sys on the dett really has no need of upgrade untill everything else is maxxed out. the old et could at least use a better coil. you caught me, this has nothing to do with ultimate power and really would be more like an external thing(see turbos and alternators above), but in the long run it would keep cost down to not upgrade your ign. system. i only mention that last part because you bring up the high cost of the dett. would this offset the other huge costs of the dett? nope. just thought id say something about it.
7)no differance? whoa, gotta take issue with that statement. inside the head alone you are looking at runner tuned for much lower rpm(the high end being well taken care of by doubling the number of runners). then if you wanted to take it into consideration the intake manifold is far superior in every way. it has higher flow capacity, better low end tuning, dual throttle bodies for a wider torque curve, etc. in this respect the dett is "da bomb" to be colloquial. just look at that massive plenum. beautiful, isnt it? wait, aesthetics are not part of this:)1 or 2 hp? i dont know how much this is all worth, but a peak hp number is absolutely useless. worth it? up to the individual. again my understanding of the arguement makes this a moot(sp?) point.
8)numbers aside, i believe more accurate to be better in this case.
9)oops, your encyclopedic knowledge of z car transmissions embarasses me. you win here too. i was in fact only refering to the old borg warner crapboxes.
a turbo cant cover up everything. i guess it would be nice to see similarly prepped engines running side by side for comparisons sake, but that will never happen. in the end nissan made their choice didnt they? their choice was the vq via the ve. thats the nissan v6 family tree. the vg is no longer a performance or even a standard engine for nissan. it is a lowly truck motor. one that is soon to be phased out. that and the dohc version is long gone.
i believe you are a "real" vg guy. something i am not. i am actually more of an sr guy though i would like to be a vh/vk guy. come to think of it, im a nissan guy.
