vg30dett into 98 froniter
doindonutz
Car: frontier
i was wondering if any one knew if the vg30dett out of a 3000zx would fit into a fronier and if so would it be worth it?
Lots of work, but no reason why not!
Might make more sense to go with the 3.5 though.
NISTECH
The vg30dett would be almost a direct drop in as the block is the same configuration as the VG33 is thats already in the frontier. The bigger part of the job would be the wiring ecm setup. You will want to go with the truck oil pan as well.
