Chingon »
https://forums.nicoclub.com/chingon-u8507.html
Thu Jan 13, 2005 4:30 pm
Latest info from fresh alloy is that a z31 transmission allows the use of a 240sx driveshaft w/o modification. Apparently from some other rumors, the z32's mounts somehow work but makes engine sit kinda high. Some guy who ran out of fund over at FA was selling a modified cross member that made things pretty simple. Anyway, it definitely fits w/o cutting, but getting it to run is another story.
Anyway, problems you may think about:sway barsteering bar (it clears in the s14 don't know if it does in the s13)oil pan s13's is front sump, don't know z32's (you may get around finding an oil pan from the pletora of other variants)If the z31's rumor is true, then no drive shaft worry.wiring:, can it be any harder than sr20/rb?tubos: There's more space up front than on the z, but I'd say single using a vg30det manifold would be best. Anyway, I considered NA a more viable, yet still fun and powerful option.weight. I collected some data, and it's lighter than the rb if I remember correctly. But I was only gathering NA info. Twin turbos get heavier. Anyway, since the engine sits way back (only about 2 inches past the strut towers, center of gravity is not thrown off.
this is what i've found out. Perhaps rear end is worth it once the power is increased. I'm not entirely sure, but swap should be simple enough. Pumpkin is bigger, and I don't quite rember if the axles are any different.
